kenpimentel Posted February 16, 2009 Share Posted February 16, 2009 We'd like to hear your thoughts on some new improvements in interop with AutoCAD and Revit. http://area.autodesk.com/index.php/blogs_ken/blog_detail/3ds_max_design_2010_improved_dwg_interop/ Link to comment Share on other sites More sharing options...
Thablanch Posted February 16, 2009 Share Posted February 16, 2009 We will see when it will be out.. ( but as it is now.. the FBX transfert is not working well most of the time, the dwg or obj transfert are still more efficient in a lot of situations) Link to comment Share on other sites More sharing options...
mattclinch Posted February 16, 2009 Share Posted February 16, 2009 looks like some good improvements. thanks. Link to comment Share on other sites More sharing options...
jackbird Posted April 2, 2009 Share Posted April 2, 2009 Just a bump, and a note that the blog post contains a MAXScript that does a very nice job of removing the 'wrong' edges from imported Revit geometry at the way bottom - that works in max versions prior to 2010 as well. Link to comment Share on other sites More sharing options...
AJLynn Posted April 2, 2009 Share Posted April 2, 2009 I used Revit 09 to Max 09 a few times with FBX and a script to remove mesh lines and found it quite effective for the "Need to do quick progress visuals right now" situation. Of course, materials changes were needed so it wasn't completely seamless. I'm also curious to see whether people think the new version is good enough for high end work. Link to comment Share on other sites More sharing options...
