Fran Posted February 16, 2009 Share Posted February 16, 2009 I was doing a very quick test scene to troubleshoot a problem for someone. The scene consisted of a room with an opening to represent a window, with Vray sun as the only lighting. It turned out very orange. I know that the height of the sun object affects the color, but it still colored the walls to an unrealistic amount no matter how high the sun was. So my dumb Vray Sun question is: how do you keep the sunlight from being so orange? Link to comment Share on other sites More sharing options...
WAcky Posted February 16, 2009 Share Posted February 16, 2009 perhaps lower the turbidity too? and try raising your ozone setting? also if you're using vrayphyscam its probaby easiest to change your whitebalance... Link to comment Share on other sites More sharing options...
Dave Oliver Posted February 17, 2009 Share Posted February 17, 2009 i know there is that set of images put out by the vray team (i think) that shows examples of all the different settings how about we just dont use vraysun until it works more like the sun in sketchup Link to comment Share on other sites More sharing options...
BrianKitts Posted February 17, 2009 Share Posted February 17, 2009 So my dumb Vray Sun question is: how do you keep the sunlight from being so orange? Use the vrayphysical camera's white balance adjustment to decrease the sun's color effect. Link to comment Share on other sites More sharing options...
Fran Posted February 17, 2009 Author Share Posted February 17, 2009 Thanks guys. I had decreased ozone and turbitity in some tests last night and that did reduce it some. I thought about adjusting the white balance in the camera settings, but D65 seems neutral enough, so I didn't change it. I'll have another look at that. I'll also take a look at the online Vray docs. Link to comment Share on other sites More sharing options...
CHE Posted February 17, 2009 Share Posted February 17, 2009 Hi Fran, Are you using a Vray Sky for the environment? If so, make sure the Vray Sun is linked to the Vray Sky. I have ran to a similar problem before and that was the issue. I hope it helps. -Ernesto Link to comment Share on other sites More sharing options...
LuckyST Posted February 20, 2009 Share Posted February 20, 2009 I agree with CHE. you most likely forgot to apply the vraysky. Link to comment Share on other sites More sharing options...
Fran Posted February 20, 2009 Author Share Posted February 20, 2009 Thanks guys. I was only trouble-shooting light leaks for another user. The sun color really didn't matter to me, but I was curious. Link to comment Share on other sites More sharing options...
