Crashes when rendering with Mental Ray
Robin3D
Hi, I need your help.. Again.
Still working on the same scenes as before. Anyway, i've got 4 similar scenes with slight differences. Though only one crashes all the time because of error: MEM 0.5 fatal 031008: can't allocate 524000 bytes. Is this a memory problem? I'm on a system with 4 GB RAM. I used to rarely get this error, but now i can't even render anymore. Though it seems it crashes at random times (sometimes in the beginning, now at pretty much halfway). Also rendering in Exposure control isn't possible.
I'm on a Vista 32 bit system.
Edited by Robin3D
A quick Google found these hits:
http://area.autodesk.com/index.php/forums/viewthread/12861/
http://www.highend3d.com/boards/index.php?showtopic=242769
http://forum.cgarena.com/viewtopic.php?t=6750
I've also found if I switch from BSP to BSP2 it helps with limited memory.
Rendering -> Render Setup -> Renderer (tab) -> Rendering Algorithms -> Ray Tracing -> Raytrace Accelleration
[x] Enable
Method: BSP2
