Michael J. Brown Posted February 18, 2009 Share Posted February 18, 2009 I've set my Irradiance Map to 'high' and still get these splotches on my walls & ceiling. In fact, those surfaces had much less splotchiness when I was running tests at 'low' IM. Could it be my antialiasing settings? I used Mitchell-Netravali with min subdivisions set to 2, and max at 4. The wall material has zero reflection and ceiling just a touch with reflection glossiness of .8 and subdivisions set to 32. What gives? BTW, there are no lights in this scene. Only daylight from a VRaySky with a sun intensity multiplier of 10. Camera shutter speed is 50 with film speed of 250 - (for sake of render speed) Thanks. Link to comment Share on other sites More sharing options...
Nic H Posted February 18, 2009 Share Posted February 18, 2009 those splotches are GI noise. Id try out using -6, -1 and 60 / 20 as far as your imap goes. illuminating the scene with sky only is going to need high GI generally. Link to comment Share on other sites More sharing options...
Brian Smith Posted February 18, 2009 Share Posted February 18, 2009 renderhaus said: I've set my Irradiance Map to 'high' and still get these splotches on my walls & ceiling. In fact, those surfaces had much less splotchiness when I was running tests at 'low' IM. Could it be my antialiasing settings? I used Mitchell-Netravali with min subdivisions set to 2, and max at 4. The wall material has zero reflection and ceiling just a touch with reflection glossiness of .8 and subdivisions set to 32. What gives? BTW, there are no lights in this scene. Only daylight from a VRaySky with a sun intensity multiplier of 10. Camera shutter speed is 50 with film speed of 250 - (for sake of render speed) Thanks. Mike, I suggest searching for posts that I've made with the keyword 'splotches'. You'll find the answers you're looking for if you do. Link to comment Share on other sites More sharing options...
Michael J. Brown Posted February 18, 2009 Author Share Posted February 18, 2009 Thanks, Brian. I'll do that. Link to comment Share on other sites More sharing options...
