slinley Posted February 19, 2009 Share Posted February 19, 2009 Existing Library being refurbished with a new bridge link and glass partitions. Comments welcome Link to comment Share on other sites More sharing options...
SandmanNinja Posted February 19, 2009 Share Posted February 19, 2009 I'd put an AO pass in there to reinforce the contact shadows. The lack of more solid-looking shadows under the chairs jumps out at me when I first see the image. Link to comment Share on other sites More sharing options...
neil poppleton Posted February 19, 2009 Share Posted February 19, 2009 Agree with the ao pass Link to comment Share on other sites More sharing options...
LuckyST Posted February 19, 2009 Share Posted February 19, 2009 whats an ao pass? Link to comment Share on other sites More sharing options...
SandmanNinja Posted February 20, 2009 Share Posted February 20, 2009 http://en.wikipedia.org/wiki/Ambient_occlusion Ambient occlusion is a shading method used in 3D computer graphics which helps add realism to local reflection models by taking into account attenuation of light due to occlusion. Ambient occlusion attempts to approximate the way light radiates in real life, especially off what are normally considered non-reflective surfaces, for example, in the way light through a small crack in the curtain in an otherwise darkened room can slightly illuminate the entire room, and not just the path of light passing through the crack itself. === There are some graphic examples on the website link, and my Avatar is an AO render. If you are using mental ray: AO Render layer The simplest way is to place a 'mental ray' material in the 'material over ride' slot and place an 'ambient occlusion map' in the surface slot of that material. Turn off GI, turn off FG, turn off Exposure, turn off all lights, then render to suit. [256 samples, HIGH Antialiasing setting, .5m max distance] [take the AO and the beauty render into photoshop, copy and past the AO onto the beauty, it gets put on the layer above the beauty. Set it to MULTIPLY, and either adjust opacity or hit LIGHTEN once or twice] There are other ways that use the AO map with lights and such but they seem a little fiddly to me. The 'best' way to do AO in my opinion is to use it in scene on the A&D shader, that way you can use the flag allowing the AO to pick up colour from surrounding materials which gives a much more accurate AO. If you use v-ray, then I can't help you. Link to comment Share on other sites More sharing options...
ezkapist Posted February 20, 2009 Share Posted February 20, 2009 Hi there, first post from me. I agree with the others the chairs look like they are floating and also unsure of the material below them.. is it carpet maybe make it stand more out weather its tiles, carpet or what not? just an idea overall nice job Link to comment Share on other sites More sharing options...
slinley Posted February 20, 2009 Author Share Posted February 20, 2009 Cheers for the comments guys, no post work has been done on this yet as i'm awaiting clients comments. Will look at adding AO. Link to comment Share on other sites More sharing options...
ankit4d Posted February 20, 2009 Share Posted February 20, 2009 I agree that chairs appear as if they are in air, There is a script to create AO pass in Vray: http://plugins.angstraum.at/vrayao/ but i prefer to add some more lights in this kind of scene to get AO under chairs. Link to comment Share on other sites More sharing options...
adamf Posted February 20, 2009 Share Posted February 20, 2009 I think more lights are the last thing it needs, the image is quite flat. I'd maybe boost the sunlight and darken the areas in shadows just to give the image some depth. An A/O pass will halp the whole image, there is a lot of detail that is getting lost because of the amount of light in the scene. Link to comment Share on other sites More sharing options...
Horhe Posted February 20, 2009 Share Posted February 20, 2009 The door in the middle looks like a texture. Agree what has been said about the AO. Link to comment Share on other sites More sharing options...
