aram Posted February 19, 2009 Share Posted February 19, 2009 Hello im still learning vray, here is my render, it has noise on the tiles and the oven hood how can i get rid of that and what other tips can you give me on improving my render thanks in advance im attaching my render settings too Link to comment Share on other sites More sharing options...
LuckyST Posted February 20, 2009 Share Posted February 20, 2009 (edited) here's a few. but you'll have to try them to see if the result would be worth the increased render time. 1st; disable render hidden lights 2nd; increase the max subdivisions in adaptive DMC rollout 3rd; try using a HDRI image for the environment slot instead of the default blue 4th; irradiance map; see if you can get better qualty by tweaking it. 5th; adaptive amount! try setting it to 1 and 0.002 . that should reduce the noise as for the materials; try changing the properties of the red material it's generating to much Global ilumination and casting a red glow on to the ceiling. 2 methods of doing that: 1st is to use vray properties (right click on the object, and then reduce the cast GI) 2nd is to use vray override material instead. as for the noise in the tiles, it could have something to do with either bump map, or your reflection parameters of the material. Edited February 20, 2009 by LuckyST Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted February 20, 2009 Share Posted February 20, 2009 Why the dutch angle? Link to comment Share on other sites More sharing options...
Fran Posted February 20, 2009 Share Posted February 20, 2009 If you have glass in the windows, exclude it from generating GI in Vray object properties. Link to comment Share on other sites More sharing options...
alias_marks Posted February 20, 2009 Share Posted February 20, 2009 good suggestions, I'd also recommend upping those min max rates on the irradiance map, unless your image is going to be uber high res. I think you'll start to find your images too flat if you lower those numbers too much for a medium res image. Looking forward to an update if you find what solved the noise problem. M- Link to comment Share on other sites More sharing options...
mhmd19732008 Posted February 20, 2009 Share Posted February 20, 2009 hello try using adaptive subdivision as an image sampler instead of adaptive QMC, you dont have too much polygon count. Link to comment Share on other sites More sharing options...
aram Posted February 24, 2009 Author Share Posted February 24, 2009 thanks for the replies everyone i change the settings to the like you guys said, it has improved, is still get some noise on the tiling though check it out Link to comment Share on other sites More sharing options...
