NoisyMonk Posted February 19, 2009 Share Posted February 19, 2009 Greetings, My first post here, and I've seached around, but haven't found anything similar. Basically the title says it all. I've got a High Poly version of a structure that is complete. I've taken all the usual steps (I've done this several times) to create a Low Poly version in order for the client to freely move around in. However when I export the file as a .w3d (with all settings maxed) I'm getting terrible Z-Depth fighting between objects, and also have Polygons disapearing at certain angles/distances. I've been able to reduce the severity of the problem slighty by slicing up large flat thin objects (a roof/wall/whatever that was made by extruding a spline) in a grid like fashion to reduce the surface area of each polygon. However, this raises the poly count, so I can't do this to every object. This only slightly reduces the problem though, not nearly enough to make it acceptable, as seen in the attached image. Due to obvious NDAs I can't show too much, but what you're looking at in that picture is a roof with a bunch of stuff showing through it that shouldn't be. Has anyone else come up with any solutions to this sort of problem? I can't just make these objects "thicker", cause that would look silly. I need a way to fix all this tearing/fighting/disapearing. Any thoughts? Thanks for your help. NoisyMonk. Link to comment Share on other sites More sharing options...
