leoviale Posted February 20, 2009 Share Posted February 20, 2009 Hi guys, I'm doing some test renders, with some trees, and I have a problem using opacity materials. Rendering leafs without opacity takes less render time. How is it possible? If i use a complete 3d tree it renders faster than a low poly tree with opacity leafs. Is there any setting or it's just a vray common problem? Link to comment Share on other sites More sharing options...
Dave Oliver Posted February 20, 2009 Share Posted February 20, 2009 (edited) could there be some other setting in the material other than the opcaity that cases it to take longer? Edited February 20, 2009 by dave5264 um Link to comment Share on other sites More sharing options...
JonRashid Posted February 20, 2009 Share Posted February 20, 2009 Doesn't the opacity have to use raytracing? Link to comment Share on other sites More sharing options...
Nic H Posted February 20, 2009 Share Posted February 20, 2009 turn off blur and bitmap filtering in the opacity map vray is faster with geometry Link to comment Share on other sites More sharing options...
leoviale Posted February 20, 2009 Author Share Posted February 20, 2009 Yeah, i completely replace my trees, to hi poly models, it's weird to see lower render times with hi poly trees w/o opacity, than a low poly model with opacity leafs... somehow there should be a way to fix that. Link to comment Share on other sites More sharing options...
mikes8500 Posted September 3, 2010 Share Posted September 3, 2010 Hi Nicnic I'm trying to optimize some Opacity Maps, where do you turn off Blur, I just see a spinner that reduces it to .01 Link to comment Share on other sites More sharing options...
leoviale Posted September 3, 2010 Author Share Posted September 3, 2010 Also changing the filter to none instead of pyramid or whatever is selected, helps allot. Link to comment Share on other sites More sharing options...
