Neil Woodhouse Posted February 20, 2009 Share Posted February 20, 2009 Greetings, I am currently working on a Viz for a Town Planner. The planner has sent me 2 photographs ( different viewpoints ) and a set of plans for the property that is to be built behind the existing house. I have decided the best way to approach this is by layering the images. I would like to have the 'rendered' image from Max with a transparent background. Awhile back someone explained to me how this was done in MAX, if i remember something to do with the alpha channel and you get 2 images. I've forgotten how to do this, can someone refresh my memory please. Next. I want the Max rendered image to be 'behind' the image that the TP has supplied me ( the new property is behind the old one ). I'm no expert on layering in Photoshop. Again can someone point me in the right direction please. The end result that i want when the images are layered is that the new property can only be seen where it should be e.g. part of the gable end, a side door etc Regards Neil Woodhouse Link to comment Share on other sites More sharing options...
Ron Schatz ASAI Posted February 20, 2009 Share Posted February 20, 2009 You are looking to comp new in to old, a layer mask on the Max image layer, over the existing photo is my most common way of do is. Does Max save a 32bit tif? if so when you load it into PS the image should be automatically clipped and needs just a layer mask add to it(see PS layer mask.JPG) the jpg show a mask just add to the building layer, with the mask highlighted paint with any brush the color black to hide more of the building or hit the x key to swap to white to fix to much hiding. That is all I have time for. Good luck rendered file over Photo and mask to fit. Link to comment Share on other sites More sharing options...
