RevitGary Posted February 20, 2009 Share Posted February 20, 2009 First off I would like to say thanks to all who have been helping me here. I am new to mental ray and revit. I am a pro at autocad and scanline. I have realized I need to be a pro at revit and mental ray. I use a shadow technique with scanline where I make an object invisible to the camera but have it cast shadows. This just makes it easy to do artsy shadows right where I want them in the viewport. I am trying to recreate this technique with mental ray with no success. how is this accomplished? I am trying to do it in object properties. Do I need to adjust the general object properties and the mental ray object properties. does the general object properties afffect the object when using metal ray? Usually i just make the object invisible to the camera and cast shadows. What metal ray options should be cheked? Link to comment Share on other sites More sharing options...
RevitGary Posted February 20, 2009 Author Share Posted February 20, 2009 Never mind I have been playing with it and I seem to have found the correct combination. I think my main problem was it was a standard material. I made it a mental ray matt material and it seems to work fine. fell free to use this technique for that added artsy look Link to comment Share on other sites More sharing options...
RevitGary Posted February 20, 2009 Author Share Posted February 20, 2009 Ok so its not working. I have it working in orthographic view. When I go to a perspective view isloating the shadows and ground it is ok. When I unhide everything Ian see my shadow objects. HELP!!!! Link to comment Share on other sites More sharing options...
