huntch3 Posted February 23, 2009 Share Posted February 23, 2009 Hi What do you think is the easiest way to cut/boolean multiple geometries to creat a section of a very comlex model...? I'm guessing you have to attach all the geometry/entities you want to cut and then use the slice tool perhaps? I wish 3dmax could boolean multiple selections at once.....thanks for your input Link to comment Share on other sites More sharing options...
BrianKitts Posted February 23, 2009 Share Posted February 23, 2009 you can select multiple objects and apply the same slice modifier to all of them at once. I normally create a selection set of those objects before applying the slice, that way it's easier to grab the full set again in the future to adjust the slice plane. as another option you could group all the objects you want to cut, and then apply your slice mod. Link to comment Share on other sites More sharing options...
huntch3 Posted February 23, 2009 Author Share Posted February 23, 2009 That works great thanks! Link to comment Share on other sites More sharing options...
