RevitGary Posted February 24, 2009 Share Posted February 24, 2009 In scanline I could make a material that would not get illuminated by lights. It would have its own self illuminating map. I have tried this in mr with no luck. Every object I create has a bright side and a shadow side. I dont want a shadow side. Any ideas? Link to comment Share on other sites More sharing options...
Justin Hunt Posted February 24, 2009 Share Posted February 24, 2009 how have you set the material up? The A&D shader has self-illumination with the option of either being physically correct or not, to have the SI emit FG samples which will case light. If all else fails a standard material still works jhv Link to comment Share on other sites More sharing options...
mattclinch Posted February 25, 2009 Share Posted February 25, 2009 you can turn off an objects visability to FG and GI in the mental ray properties tab - this should make it unaffected by lights, and then make it self illuminated. Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted February 26, 2009 Share Posted February 26, 2009 I seem to be having the right kind of luck with a Mental Ray meterial with color info (gradient, bitmap) for a Surface shader and everything else none. Link to comment Share on other sites More sharing options...
