Vray Dancing Shadows
cjlopez4
I have an animation that when rendered on my home PC, renders fine very little flicker or shadow dancing on flat wall surfaces. However, when I ran it on the render farm service, the animation has cone back with flicker and dancing shadows. Any way to fix this is post or do I need to re-run the animation without LC and only produce it with IRR?
Hi Cesar,
I got a similar effect when doing my animations, I found that just by pumping up my HSph Subs and adding more passes to the IR, the shadows went? Haven't tried it on a network though.
Hope you find your answer
Marc
I switched to BruteForce 1/100, .85/.005 no more problems, slightly longer render time but the dancing shadows and flicker are gone. Not using secondary bounce, tweaked color mapping and camera for desired lighting.
