omid Posted February 26, 2009 Share Posted February 26, 2009 hi everyone i have problem with 3D Studio Max in opening file in the max 9...Can i open max Files Saved With 3dsmax 2009 or 2008 in max 9...? is there any Script to do that..? thanx Link to comment Share on other sites More sharing options...
batfink82 Posted February 26, 2009 Share Posted February 26, 2009 No you can't open a MAX 2008/9 file in MAX 9. You can export the file using a BFF exporter script from MAX 2008/9, this can then be opened in any version of MAX as it converts the geometry into a .ms (script) file. You can download the script from 'scriptspot.com' Hope this helps.............. Link to comment Share on other sites More sharing options...
quizzy Posted February 26, 2009 Share Posted February 26, 2009 i would go with FBX export-import. this topic is repeating itself too many times, next time, the search option would be your first answer..... ***thread closed*** Link to comment Share on other sites More sharing options...
