davidarcila Posted February 26, 2009 Share Posted February 26, 2009 Hello, i didn't post this in other threads because it doesn't have to do with architectural rendering, but still i know there are lots of people here that can help me with this problem. I'm modelling a small soda can using 3ds max, i started the can as a cylinder and that part is ready. But when i get to the top part things get more complicated, because i don't know how to approach the modelling of the pull tab. I tried using splines and then extruding them, but the issue here is that i don't have enough subdivisions for the turbosmooth to work. How would you approach this? Thanks Link to comment Share on other sites More sharing options...
SandmanNinja Posted February 27, 2009 Share Posted February 27, 2009 just keep it a spline. Looks like you have the basic shape there. Just extrude the splines to give it some thickness and you should be right. Link to comment Share on other sites More sharing options...
Ky Lane Posted February 27, 2009 Share Posted February 27, 2009 (edited) I think youre trying to round off the edges? This is where my modelling skills get stretched. Personally, Id convert it to a poly, grab all the outer edges and camfer them. This may help : http://www.worldoftrainz.com/Pages/TutorialsTRS/3dsRadiusEdgeTutTRS.htm Edited February 27, 2009 by Ky Lane Link to comment Share on other sites More sharing options...
shaneis Posted February 27, 2009 Share Posted February 27, 2009 Why not just do a simple low-poly box model, do a simple bevel around all edges and then convert to sub-d's or whatever the Max equivalent is...turbosmooth? Link to comment Share on other sites More sharing options...
anton Posted February 27, 2009 Share Posted February 27, 2009 You have enough subdivisions, but the problem is with the top and bottom polygons that have a very bad topology. For turbosmooth to work you need a somewhat clean model, as close as possible to having only quads. I would build this using an organic modeling technique. Build one polygon and shift+drag the edges to create new polygons. This way you create a low poly model that approximates the tab, then you extrude it and add the turbosmooth. Link to comment Share on other sites More sharing options...
Justin Hunt Posted February 27, 2009 Share Posted February 27, 2009 Poly box model with turbo smooth and a bend for fun not perfect by should be a good start jhv Link to comment Share on other sites More sharing options...
SandmanNinja Posted February 27, 2009 Share Posted February 27, 2009 yeah - what he said Link to comment Share on other sites More sharing options...
Ky Lane Posted February 27, 2009 Share Posted February 27, 2009 yeah - what they said Link to comment Share on other sites More sharing options...
davidarcila Posted February 27, 2009 Author Share Posted February 27, 2009 thanks for your help, i'm currently doing the model with the suggestions you all made. Thank you very much. Link to comment Share on other sites More sharing options...
