Cuastic render error?
RevitGary
Select the Daylight, right click->properties, mental ray tab, and check "Generate Caustics"
If you want *only* the Sun and not the Sky to produce Caustic photons, the select the Daylight, on the menu bar, go to Group->Assembly->Open
Then you can select the Sun and Sky seperately to apply different object properties to, such as generating caustics.
^^-Excellent point
Definately the best way to go for hero objects(though make sure the light is only set to affect the hero object).
In the same spirit, I'd like to append my previous post by saying that if in the OP's scene the pool takes up a broader amount of the final image, using the Photon Target in the mrSun may help (provided that you are not using GI photons for the entire scene and you only need the photons for caustics - just focus it to encompass the water. You may get wonky results if you need the photons for GI in a broad shot with the focus in one area)
Another thought: if you are only trying to create refractive caustic effects on the pool's shell, faking it with the material could be much quicker.
Edited by luckymutt
spelling msakite
