ezkapist Posted February 27, 2009 Share Posted February 27, 2009 Hi guys, as i mentioned in my first interior thread im new to rendering but find that im loving it. this is my new exterior rendering and need some feedback on it. This is all work for my personal portfolio. (that will hopefully get me a job in cg) i will furnish the insides soon and ad a physical light on the spotlight. anything else please critique thanks for all B Link to comment Share on other sites More sharing options...
batfink82 Posted February 27, 2009 Share Posted February 27, 2009 Hi there, I like it but there is a few things i would adjust............ 1. put some trees or something on the far right hand side to block off the image, your eye just goes straight to the end of the earth. and think about horizion lines and how your sky sits in the image. 2. the tile material looks odd, the grout lines are too wide and the tiles maybe too small? 3. I would put some glass doors in as the ground level as the access to the pool/loungers. I looks a little strange having such a large white wall, these doors could be framed with some good trees/climbers? More detail and light at the ground level will improve the image. 4. i would lose the umbrella, i dont think sunburn is a risk in a night shot...... 5. the curtains on the second floor dont quite work, maybe swap for an open curtains with some light between. 6. i would put some LEDs just below the water line of the pool, then darken it slightly away from the lights. 7. lastly I would put some plants on the balconies etc to soften the image slightly. Hope this help........... Link to comment Share on other sites More sharing options...
ezkapist Posted February 27, 2009 Author Share Posted February 27, 2009 hi, thanks a lot for that advice, im working on this one without any references purely out of my head so its a bit harder as I am not an architect.. but i will get there.. here is a small update.. i still have more of your ideas to implement.. this is, what is so far... thanks again b Link to comment Share on other sites More sharing options...
batfink82 Posted March 1, 2009 Share Posted March 1, 2009 I think the new image is much better. But it could still do with more windows on the ground floor behind the loungers. I would also look at trying some HDRI sunset environment maps. This will give your image a more realistic colouring. Night shots are a more expressive version of a day shot it should bring out different features of the building. If you want to use this as a portfolio piece you need to incorporate some of the techniques used in the industry. HDRI is used quite extensively to produce night shots and I think it could work well for you in this instance. Link to comment Share on other sites More sharing options...
ezkapist Posted March 1, 2009 Author Share Posted March 1, 2009 Hi, i am using a dosch hdri night map but i think its pointless as it is almost no effect at all.. i wanted to do a twilight shot but dont have a good HDRI map.. I will try a few other ones and update soon. thanks for that Link to comment Share on other sites More sharing options...
innerdream Posted March 1, 2009 Share Posted March 1, 2009 ezkapist said: Hi, i am using a dosch hdri night map but i think its pointless as it is almost no effect at all.. i wanted to do a twilight shot but dont have a good HDRI map.. I will try a few other ones and update soon. thanks for that Here are some free hdri's for: http://www.evermotion.org/index.php?unfold_exclusive=84&unfold=exclusive Keep at it. Link to comment Share on other sites More sharing options...
ezkapist Posted March 1, 2009 Author Share Posted March 1, 2009 Hi there, thanks for all guys, didn't know evermotion had free hdris - thank you. attached is the latest version of the render. b Link to comment Share on other sites More sharing options...
