isaac_cm Posted February 28, 2009 Share Posted February 28, 2009 Hello, I found that many times I cant select an edge or vertex that the polygon need to apply an xform on it !! but I found that really odd!! I study Maya for a while and it does not has something like that at all !! or is it my max version 9 and I should use latest version ?? Link to comment Share on other sites More sharing options...
BrianKitts Posted March 1, 2009 Share Posted March 1, 2009 the only time I have trouble selecting polys, is when trying from the back side, orbiting around the object in the viewport normally fixes this. But this isn't something I think xForm would fix..... Link to comment Share on other sites More sharing options...
JonRashid Posted March 1, 2009 Share Posted March 1, 2009 Try turning off backface cull in display properties. While it's on you can only select if things are actually facing you in viewport Link to comment Share on other sites More sharing options...
isaac_cm Posted March 1, 2009 Author Share Posted March 1, 2009 yes I was selecting the object from the back but rotate never fix it only applying xofrm did !! I find xform usage is kind of odd !! Link to comment Share on other sites More sharing options...
