rendering
abro
Search the forum and you will find your answer. Here is an overview of what you will find:
You can comp it in post.
You can texture map the stuff and trick it up with a good Blend material and Noise map in the diffuse slot.
You can try Hair/Fur and or displacement.
You use physical geometry, instance it and distribute it.
