Tim Saunders Posted March 3, 2009 Share Posted March 3, 2009 Not sure if this is the best place for this, but I couldn't find a place more specific. I'm doing a toon animation of a sort-of walk-through, and I want it to like like a flip book animation. I figured out how to make it just jittery enough, but now I want to ad some dark blinks between the frames. I started using the Strobe Light effect, but had it flash dark instead of light, but for some reason that effect blinks like six times, takes a break, then repeats. I can't seem to make the effect constant, with no breaks. Is there a better way to set this up, another effect that works better, or should I adjust some of my parameters? See my Strobe Light effects settings attached. Link to comment Share on other sites More sharing options...
Tim Saunders Posted March 3, 2009 Author Share Posted March 3, 2009 Ah, never mind. I ended up creating an action in Photoshop to just darken each frame a little bit, then doing a save as. Then I did an Automate-batch, and re-saved my original frames, and the darkened frames with new names. That way I could import all the new files as numbered stills. It looks perfect. It's still weird that I couldn't get the strobe to do what I wanted it to do. Link to comment Share on other sites More sharing options...
mattclinch Posted March 3, 2009 Share Posted March 3, 2009 your strobe duration is the value in seconds that each strobe lasts - if you want every other frame i think you would divide 1 sec by half your frame rate - so for 30fps it would be 1/15 = 0.0666 or 0.07. the strobe period i think is the delay between each set of strobes... so for continuous i think you set this at 0. i dont have AE infront of me right this second, but i think you are going about it the best way - this is certainly how i would get this effect. good luck! Link to comment Share on other sites More sharing options...
Tim Saunders Posted March 3, 2009 Author Share Posted March 3, 2009 That's what I would have thought. When I set it to zero, I got no effect at all. Weird aye? Link to comment Share on other sites More sharing options...
mattclinch Posted March 3, 2009 Share Posted March 3, 2009 hmm.. perhaps set it very high - as long as your animation in seconds? might be the total period the strobe works over. Link to comment Share on other sites More sharing options...
