MegaPixel Posted March 5, 2009 Share Posted March 5, 2009 (edited) Has anyone had a chance to setup a multi-PC backburner render network using Windows 7 beta yet? I’ve noticed that the rendering performance of the Win7 x64 beta server nodes is taking twice, if not 3 times longer on average to complete frames then the WinXP x64 server nodes of equivalent hardware spec. which is puzzling me. I’m using a mixed OS network (XP, XP64, Win7 64) here at work. I’m using Windows 2008 Server OS 32bit for the manager PC (to allow for more then 10 concurrent PC connections) and all other server nodes are running Max 2009 Design 64bit - Network is still IPv4 with gigabit connection. In doing some individual Win7 beta render node testing, I notcied that on occasion, after prematurly canceling a render job, that the render node PC would not return to its “pre-render” performance level - That is to say there were still process’s running in the background (like extra svhost.exe’s,etc...) eating up valuable processor cycles for no apparent reason and grindign the system to a hault. I've also just learned over in the Autodesk Area Forums that Vista x64 has very similar speed problems when rendering. At any rate, I was hoping someone could confirm these findings and or perhaps shed some light on how to adjust the OS to overcome these render speed delays? Thanks - Pixel Edited March 5, 2009 by MegaPixel Link to comment Share on other sites More sharing options...
AJLynn Posted March 5, 2009 Share Posted March 5, 2009 I would NOT try using the Windows 7 beta in any serious context. It's beta, you don't know what's wrong with it and what they're going to add/subtract/rewrite, and there's no good reason to be using it. Stick with what you know works - XP64. Link to comment Share on other sites More sharing options...
MegaPixel Posted March 5, 2009 Author Share Posted March 5, 2009 Point taken, however let me explain our reasoning for using it. We needed to quickly add 6 offline PCs to the render farm for a "finite" amount of time. With budgets "slim" these days, we didn't want to have to purchase 6 additional XP64 seats for what will only be needed for a few months tops. Windows 7 Beta is free to use until August of this year so I figured, what the heck. Outside of rendering, the OS actually seems pretty decent and snappy and was also the easiest/quickest install and setup I've ever experienced. I know it's a beta and I'll take whatever I can get out of it, but I was still curious to know if anyone else had a chance to experience and overcome what I'm going through right now. Thanks - Pixel Link to comment Share on other sites More sharing options...
quizzy Posted March 6, 2009 Share Posted March 6, 2009 When microsoft windows works faster, it usually means higher cpu usage instead of optimizing the actual software.. ;-) Link to comment Share on other sites More sharing options...
Justin Hunt Posted March 6, 2009 Share Posted March 6, 2009 we installed win7 on an old P4 with only 500mb ram, supprisingly it runs pretty well. Obviously we're not rendering on it, just having a poke around. jhv Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted March 6, 2009 Share Posted March 6, 2009 I've got a question out but no reply yet. Gimme a sec, I'll check the web... ...Can't tell for sure at a quick glance. Anyway, betas have a way of being debug builds which include lots of extra cruft that will slow things down. From the web it looks like the Win 7b comes in two flavours, a full on debug build with lots of extra processes and no optimizations and maybe even extra data pushing that a compiler will put in to aid in getting info out of the code when needed (good for developers and feedback to MS)... and a more normal use version for people who don't need to get in to the internals so much. The wording of what I read made me believe that this regular folks version does still have some debug material. That could be what is slowing you down. Link to comment Share on other sites More sharing options...
