Sargimo Posted March 5, 2009 Share Posted March 5, 2009 (edited) I Import this linework into Max, Extrude with a modifier, select all, apply a two sided material, As i rotate the model in the viewport the walls come and go. Can anyone tell me what I need to do to see both sides of the walls as I navigate the drawing. I've tried alot of things, too many to mention here. Thanx in advance for any help. The linework is attached P.S. AAAAAAAAHHHHHH!!!!!!!! Edited March 5, 2009 by Sargimo Link to comment Share on other sites More sharing options...
Tommy Burns Posted March 7, 2009 Share Posted March 7, 2009 Convert to editable poly/mesh by selecting all then right click convert to poly/mesh. Then select what faces aren't showing and flip the normals. Hope this helps Tommy Link to comment Share on other sites More sharing options...
frruger Posted March 7, 2009 Share Posted March 7, 2009 Clean up the line work, it is impossible to be extruded on a useful mesh object as it is. Link to comment Share on other sites More sharing options...
Sargimo Posted March 20, 2009 Author Share Posted March 20, 2009 thanks guys, I cleaned up the linework and converted then flipped the normals all is good, Many thanks for your patients and reply, Josh Link to comment Share on other sites More sharing options...
