RevitGary Posted April 6, 2009 Author Share Posted April 6, 2009 OK AJ... I noticed I can get a i7 4 ghz for about the same price as dual 2.26 ghz. I am assuming that is the way to go. I am looking for bench marks but cant find what I am looking for. I am assuming the rendering times in mental ray will be almost the same. And the speed for all other apps will be considerably faster. you have any idea about rendering times with these two options? Thanks for all you advice. Link to comment Share on other sites More sharing options...
AJLynn Posted April 7, 2009 Share Posted April 7, 2009 Yeah, it should work out about like that. The dual would probably be a bit faster than the OC'ed box in rendering but probably not much. But I haven't seen enough workup on both the options... are these both Boxx products? Boxx should have pretty comprehensive test results on both, so talk with somebody there and ask these questions. Link to comment Share on other sites More sharing options...
RevitGary Posted April 7, 2009 Author Share Posted April 7, 2009 yess they are both boxx It was the end of the day when I came up with this question. The tech guy wasnt there. I will be speaking with them tomorrow. Thanks!! Link to comment Share on other sites More sharing options...
BOXXLABS Posted April 13, 2009 Share Posted April 13, 2009 I've been traveling for a while and not checking the forums... NOt sure if you got in touch with the sales engineers but I can chime in here and provide some direction... Revit is basically a single-threaded application. Revit really likes very fast clock speeds on a single core. So, for most processes in Revit, the 3DBOXX 4850 Extreme (singke i7 at 4Ghz) will kill about any other system on the planet. Period. This includes any and all dual Nehalem Xeons available. This includes any time-consuming operations such as surface re-ordering/rebuilding on large projects/assemblies. For final rendering in mental ray (and other modern raytyracing engines), the 4850 Extreme @ 4Ghz is almost the same speed (slightly faster actually) as a system using a pair of Xeon 5520s cpu's. If you do a ton of renders, you may want to look at a dual Xeon setup. If you spend more time rendering than modeling, you should probably look at a seat of 3DSMAX and some dedicated renderfarm hardware. **I forgot to mention, but if your Revit projects are really large, you definielty should consider moving to Revit 64 bit on a 64-bit system with at least 8 or 12 GB or RAM. Cheers, Adam BOXXlabs Link to comment Share on other sites More sharing options...
RevitGary Posted April 13, 2009 Author Share Posted April 13, 2009 I ordered this BOXX 4850 Exxtreme Series Configuration Intel i7 Quad Core Enhanced Performance Processor (4.0 Ghz) 12GB DDR3 1333 (6 DIMMS) ATI FireGL V7600 512MB - Extended Lead Time USB External Floppy Drive 250GB 7,200rpm SATA 500GB 7,200rpm SATA 20X Dual Layer DVD–RW Writer Microsoft Office 2007 Small Business Edition (No Media) Microsoft Windows Vista Business Edition 64-Bit USB Keyboard Logitech MX 400 Corded Mouse BOXX 3 YEAR LIMITED WARRANTY Model Specifications Intelfi Core.i7 Extreme / Core.i7 Intelfi X58 / ICH10R Nvidiafi nForce 200 Three Channel DDR3-1066-1600 . . (6 DIMMS) (6) Serial ATA 3Gb/s ports . . (RAID 0 and 1) (2) SAS ports . . (RAID 0 and 1) (2) Gigabit Ethernet port 7.1 HD Audio . . Front panel mic + audio out (1) S/PDIF Out (Coaxial + Optical) (8) USB 2.0 ports: . . (2) Front, (6) Rear (2) e-SATA ports 1000W Power Supply 4U: 7"w x 17"h x 19"d Expansion options: (4) 3.5" hard drive bays (2) PCIe 2.0 x16 slots (at x16 or x8 mode) (1) PCIe 2.0 x16 slots (at x16 mode) (2) PCIe 2.0 x16 slots (at x8 mode) (1) PCIe 2.0 x16 slot (at x4 mode) Link to comment Share on other sites More sharing options...
AJLynn Posted April 13, 2009 Share Posted April 13, 2009 Yeah, you've got yourself a bit of power there. Link to comment Share on other sites More sharing options...
Tommy L Posted April 13, 2009 Share Posted April 13, 2009 So did you buy 2? I seem to remember this thread stated as a 'mobile workstation to take to and from work' thread....? Oh, and the magic question, how much did the system cost? Link to comment Share on other sites More sharing options...
RevitGary Posted April 13, 2009 Author Share Posted April 13, 2009 I decided to get one stay at home workstation 5,700 Link to comment Share on other sites More sharing options...
Tommy L Posted April 13, 2009 Share Posted April 13, 2009 Enjoy your new machine! Link to comment Share on other sites More sharing options...
RevitGary Posted April 25, 2009 Author Share Posted April 25, 2009 Got my boxx im a happy camper. Thanks to all. Now I am trying to figure out how to apply my materials that are on my work server to my home computer. I have all the files I just dont understand how to make max find them. My work drive is "p" my home is "s" i have no idea how to change the s to p Link to comment Share on other sites More sharing options...
