simple Flash help (I think)
BrianKitts
I'm new to using flash, but have a director background... so most of it makes sense, but now I'm stuck on the last part, any help would be appreciated.
I'm working on a presentation that has to be embedded in powerpoint. So to get the control that I want I'm embedding the animation in flash and then adding the needed navigation.
Basically there's a video on the screen, and the timeline has stopping points at specific frames of the animation. Then the user has a "next" button to continue playing the animation. All this works great, so now I want to add a combobox dropdown menu with all the stopping points to allow the user to jump backwards to specific points if need be.
basically I can't figure out how to do a gotoAndPlay and pull the data value from the dropdown menu. Here's what I have so far...
//navigation menu
import fl.data.DataProvider;
import fl.events.ComponentEvent;
var items:Array = [
{label:"Existing", data:"01"},
{label:"Demo", data:"20"},
{label:"Add. Floors", data:"120"},
{label:"Seismic", data:"178"},
{label:"Bathrooms", data:"238"},
{label:"Elevators", data:"286"},
navMenu.dataProvider = new DataProvider(items);
navMenu.addEventListener(Event.CHANGE, ItmChng)
function ItmChng(e:Event):void
nav = navMenu.getValue();
gotoAndPlay(nav);
I can remove the "nav" variable and just put in a number to the gotoAndPlay line and it works, so I just need to figure out how to use the data value from the dropdown....
any ideas?
