nelpiper Posted March 10, 2009 Share Posted March 10, 2009 Hi guys. I have to 3d track a footage and bring the camera data over to MAX so that I can composite a building into the footage. Does anyone know accurately what would be the scale from boujou to MAX? Thanks. Link to comment Share on other sites More sharing options...
anton Posted March 10, 2009 Share Posted March 10, 2009 Do you have any measured points or GPS done for the footage? If you have that it the actual units don't make a big difference as you can rescale it in max. But if you don't have any kind of real world measurements then you'll have to do the scalling using some sort of reference. What I am doing is using Google maps or any mapping application and get some printscreens of the area of the project. Map them on a plane and try to scale it to your project. Existing topography and civil linework would make a huge difference in accuracy. Once you have that scaled properly it will be so much easier to scale your 3d solution from boujou as you can match some of your trackers to that map. Link to comment Share on other sites More sharing options...
Nils Norgren Posted March 10, 2009 Share Posted March 10, 2009 If you are using Boujou Bullet the tracking data is scaleless, there are tools within Bullet that will allow you to move/rotate/scale the cloud of points and camera, but the best bet is to try to get the data to have a reliable UP axis, and then import everything into max and then move/rotate/scale the data to match the context of your 3d scene. The bullet data has a "main" point that all the rest of the data is linked to, if you only transform this object the whole camera track will come with it. There is one big headache with this solution is that the camera will most likely end up scaled, which can cause problems with motion blur and some render packages. The best bet is to use a script to re-scale (without affecting the rest of the transform) the camera to [1,1,1] Hope this helps, This is for Boujou Bullet, the full version of Boujou may have better ways of getting the data better correlated. -Nils Link to comment Share on other sites More sharing options...
nelpiper Posted March 11, 2009 Author Share Posted March 11, 2009 Hi guys. At exporting from boujou, I scaled the scene up to 50000 which seemed to have worked fairly well. Now the problem is to match my model to the tracking points. Does anyone can give me any tips? Thanks. Link to comment Share on other sites More sharing options...
