sourabhb Posted March 10, 2009 Share Posted March 10, 2009 Hello everyone,this is my first attempt to render interior Scene using radiosity.i am facing some problems with my render,nedded some help with my render,will be really greatful A) Getting light lekouts in this area B)black dots appearing in ceiling pattern C)any Parameter,to achieve glossy reflections on floor(Like in Vray,by reducing refl. glossiness value)..and not these "water type" reflections. D)have added one omni inside lamp...though light is scattering around the sorroundings..but i am not able to light up my lamp. Attaching my scene render and render settings...i have used daylight system and added 2 point lights in my scene Link to comment Share on other sites More sharing options...
disidente Posted March 11, 2009 Share Posted March 11, 2009 try to make your omni light a inverse square decay. try to add some opacity & self ilumination to the lamp material Link to comment Share on other sites More sharing options...
John Dollus Posted March 11, 2009 Share Posted March 11, 2009 A. looks like a light leak - check the geometry there to make sure both surfaces terminate at an edge and they don't run beyond each other. Accurate modeling is essential with radiosity. B. looks like it could be a smoothing group issue - if you created the ceiling detail with a sweep, make sure you smooth along the shape but not the path c. depends greatly on the material - can you post your floor material settings? Link to comment Share on other sites More sharing options...
sourabhb Posted March 12, 2009 Author Share Posted March 12, 2009 Thanks for the reply sir ...i am attaching the floor material which i have applied in my scene Link to comment Share on other sites More sharing options...
