Boing Posted March 12, 2009 Share Posted March 12, 2009 if i have several elements in vray (z pass, atmosphere etc) and i set it to auto save it'll only save the render, not the elements. the standard frame buffer will save the individual elements but i prefer using the VFB. how can i gat the VFB to save out the seperate render elements automatically? Link to comment Share on other sites More sharing options...
BrianKitts Posted March 12, 2009 Share Posted March 12, 2009 the option is right there in the same box where you enabled the vray frame buffer.... Link to comment Share on other sites More sharing options...
kippu Posted March 12, 2009 Share Posted March 12, 2009 wow , i learn something new everyday .. thanks brian Link to comment Share on other sites More sharing options...
Boing Posted March 12, 2009 Author Share Posted March 12, 2009 excellent, thanks very much Brian. Link to comment Share on other sites More sharing options...
WAcky Posted March 13, 2009 Share Posted March 13, 2009 A word of caution though! I sometimes forget to uncheck this box after my render and then can lose some passes on re-renders Link to comment Share on other sites More sharing options...
BrianKitts Posted March 13, 2009 Share Posted March 13, 2009 WAcky said: A word of caution though! I sometimes forget to uncheck this box after my render and then can lose some passes on re-renders That's a good point, I really wish this option didn't have the filename as part of the setup. It should just be an on/off tick box that when selected it takes the filename out of max's save file dialogue and tags the channel name on to the end of it to make the file name. And then drops the file in the same place max is set to. Link to comment Share on other sites More sharing options...
vincent_icon Posted December 30, 2011 Share Posted December 30, 2011 Great! I was wondering about this too! Another doubt i came up with was, is there an option not to render the final image, but only the passes? It would be faster right? Because VBF shows the final result and then the other passes... I dont know if you can understand what i mean. Link to comment Share on other sites More sharing options...
RyderSK Posted January 4, 2012 Share Posted January 4, 2012 vincent_icon said: Great! I was wondering about this too! Another doubt i came up with was, is there an option not to render the final image, but only the passes? It would be faster right? Because VBF shows the final result and then the other passes... I dont know if you can understand what i mean. I think they should really do this, considering how many people ask for it and seems to only be logical. Everyone will suggest you to lower your render settings as low as possible, even turn of GI, and render. Link to comment Share on other sites More sharing options...
Chris62 Posted February 3, 2012 Share Posted February 3, 2012 BrianKitts said: the option is right there in the same box where you enabled the vray frame buffer.... I have my settings as in the reference image but still doesnt save out when FB is enabled. You have to uncheck so whats the advantage of using this option? You can just save via the render elements tab. Link to comment Share on other sites More sharing options...
marcobossow Posted July 21, 2012 Share Posted July 21, 2012 (edited) I'm having the same problem, but can't view the picture Brian attached. It was displayed as a link before I registered, but after I logged in, the link simply disappeared. Now it just says: "Attached thumbnails" with a paperclipsymbol , but there is no picture. Tried in both Firefox 13 and IE 10. Edited July 21, 2012 by marcobossow Link to comment Share on other sites More sharing options...
juliancrespi Posted May 24, 2013 Share Posted May 24, 2013 marcobossow said: I'm having the same problem, but can't view the picture Brian attached. It was displayed as a link before I registered, but after I logged in, the link simply disappeared. Now it just says: "Attached thumbnails" with a paperclipsymbol , but there is no picture. Tried in both Firefox 13 and IE 10. Hey Marco, happened the same to me but found how to fix it: In the vray tab in render settings, in V-Ray:: Frame buffer, you have to enable Split render channels, by ticking the Save separate render channels and unticcking Save RGB and Save Alpha (because those are saved in your original render). I imagine the idea behind it is to save the channels in a format like .exr, but evidently it's a problem by saving in a png, so you need to separate the channels in different files. Hope it works for you! Link to comment Share on other sites More sharing options...
miroslavhrusovsky Posted December 8, 2013 Share Posted December 8, 2013 sorry, I cannot find attached image. Can you explain by few words? Link to comment Share on other sites More sharing options...
markhana Posted January 3, 2014 Share Posted January 3, 2014 I have 2 problems in 3d max scene, First one is that scene is too heavy when working, Although It has more than 20 Millions face or poly, But I have high performance workstation, Dual xeon 2.3 16 core, 32 gb ram, And 3Gb Quadro Pro Video, 3d max process take less than 8 Percent while working ,What should I do to make the 3d max process take more Percent of processor, Second Question, Is After rendering, The shot couldn't be saved, Save window takes a lot of time hanging , Appear and disappear, What Should I do to avoid that, Anyone could help , Thank You Link to comment Share on other sites More sharing options...
marcelo fernandes Posted March 24, 2014 Share Posted March 24, 2014 You need to deactivate an option called increase quality gradually (or something like that. i can't open 3ds right now.) its under the viewport settings or something. Had the same problem when switched to max.2012. Hope it helps! Link to comment Share on other sites More sharing options...
markhana Posted March 24, 2014 Share Posted March 24, 2014 Thank you Marcelo so much, I got it after along time, Also after I switched graphic mode from Nitrous to direct x , it goes more fast, But my only problem now, Is when I save the 3d shot, it looks a little bit blurry when you open it in photoshop, I tried everything in save and also , I tried 16 bit? Any help?. Link to comment Share on other sites More sharing options...
avghh Posted June 9, 2014 Share Posted June 9, 2014 (edited) Does checking "Separate render channels" work if I save my sequence of renders from "Render Outputs" of "State Sets? If no, what should I do to have sequence of ZDepth and other passes separately during main pass render? Edited June 9, 2014 by avghh Link to comment Share on other sites More sharing options...
