Photoshop CS4 Performance
We finally received our upgrade to CS4 a couple of days ago. I haven't worked extensively with Photoshop yet, but has anyone else noticed a slowdown in its performance? When I am working in it, it doesn't seem as responsive. The windows drag a bit, things are slow to react, etc... Basically, it seems like one of those upgrades where the code hasn't been fully optimized. It has happened in other software I have used in the past, and it feels like this may be the case for Photoshop. At least this release of Photoshop.
Also, my brush size seems buggy, and a few other icons are just simply not showing up.
Edited by Crazy Homeless Guy
Hi
Interesting. I upgraded to cs4 a couple months back on my personal laptop, haven't had any issues with slow performance with ps or any of the other applications in cs. And this is even with 3ds max running simultaneously. all icon are there, brush work fine.
Was it installed locally or over the network?
Installed as a network deployment.
Maybe I will download the demo to try on my home computer to see how the performance compares.
I agree about being able to run Max and Photoshop at the same time. It is not that uncommon for me to have several images open in Photoshop, and be running 1 or 2 instances of Max at the same time. But that was with CS3.
you're not missing much ;)
I've found most of the 'new hotness' features that they announced was actually slowing me down. main advantage being the 64bit version being slightly more stable on stupidlarge comps. and occasionally photomerge for quicky panos!
But yea, disable OpenGL unless you've got a beastly firegl/quadro I think, and it'll feel much more like CS3
only stability?
How about much faster opening files, much faster doing anything, how about that I can assign 6.5GB of my 8GB of Ram to Photoshop and it uses it all up doing wonderful things?
y
Is this at operating system level, or application level in Photoshop? ...I can't seem to find it.
Edit:
Never mid, I found them. They are grayed out on my current machine, which has a Quadro 1700. I am going to update to the latest GPU driver to see if that helps.
I started rooting around in Photoshop today, trying to get it to behave like it used to. I was able to disable the tab feature that they rolled out, and that seems to have improved performance. Well, I disabled a few things, but I am pretty sure tabs are what is causing the lag.
Not super fast now, but definitely noticeably faster than it was.
I guess I expect software to move at a certain clip, and if it isn't, I notice because it is slowing me down.
  • 3 weeks later...
Have you guys upgraded to the new version. 11.01? I noticed it sped up a fair bit after I did that. Still testing though. I just upgraded this weekend for a project and it was the first time I found PS to be slow. I was using dual GeForce 7900 GTX cards too.
Have you figured out how to make tabs go away altogether? They do not come up when you use File>Open, but they are still being used if you drag a files into the Photoshop interface.
I haven't ran the update yet, I will do that today and see if it helps. Right now I am noticing that the performance isn't that bad when I fist stat working, but quickly degrades as I wok on large files. Purging doesn't help, but restarting Photoshop does.
I found that gradual degredation went away after the update.
so last night I was doing some more work and I ran into all sorts of lag when working. Today I upgraded my video card drivers to the latest version and also enabled SLI. Somewhere along the line I disabled it to test something and forgot about it. Once I did that, the performance it lightning fast and responsive. Apparently Photoshop now needs dual GPUs to work properly LOL.
  • 3 weeks later...
