Solid State Drive
I looked into it for a new system I had built.http://www.cgarchitect.com/vb/34858-time-new-computer-again.html
As I looked into them it appeared that there were some real issues with setting them up for typical usage becuase write speed is very slow. Read speed is through the roof, but if you install the OS on one of these (which would be the only benefit as I could see it, no way I could wait for large files to be written) it will constantly be writing small files to it. There are some work arounds for this but It seemed rather complicated and still a bit buggy. I decided to stay away for now. I think the future may be heading this way one day though.
It's obvious from what I've read that the SSD's have moderately slow write speeds, could you somewhat bypass this by setting all of your programs to use the secondary mechanical drive as your disk cache? That would eliminate most of the writing done by programs while taking advantage of the massive read speed.
lol
www.tomshardware.com/reviews/ssd-memoright,1926-10.html
"It doesn’t matter which benchmark pattern you compare; Memoright beats the pants off the conventional hard drives."
"If you can live with the fact that these drives will probably cost half of today’s cost or maybe only a third by the end of this year, then you can go for it, as you can be sure to get the very best hard drive available."
  • 2 months later...
I'm currently running (as a default config)...
Primary Drive (program/system files)
Intel X25-M 80 gb SSD
Second Drives (Textures/Materials/Scenes/Data/etc)
Raid 1 WD Caviar Black or WD RE3
I'm a big fan of having some sort of redundant drive system setup for the actual data files. If the system/program drive goes down...that's recoverable. If you lose weeks of work...that's devastating.
