nodar1978 Posted March 14, 2009 Share Posted March 14, 2009 hello guys i need this form to extrude 10cm on a ceiling, do you have any other idea except the make this form with lines and then extrude it? displacement doesn't work good. thanks Link to comment Share on other sites More sharing options...
Tim Nelson Posted March 14, 2009 Share Posted March 14, 2009 I'd say for the best results you'll have to trace it - either with splines in max, or in a higher resolution image in photoshop to get clean smooth lines. This was the best I could quickly do with displacement. I enlarged it in photoshop and did a levels adjustment and painted out some spots. Its not bad, but you can still see the irregular edges. Link to comment Share on other sites More sharing options...
nodar1978 Posted March 14, 2009 Author Share Posted March 14, 2009 I'd say for the best results you'll have to trace it - either with splines in max, or in a higher resolution image in photoshop to get clean smooth lines. This was the best I could quickly do with displacement. I enlarged it in photoshop and did a levels adjustment and painted out some spots. Its not bad, but you can still see the irregular edges. Hello and thank you very much for your quick help Link to comment Share on other sites More sharing options...
AJLynn Posted March 14, 2009 Share Posted March 14, 2009 Just to see I ran Live Trace in Illustrator on it at default B&W settings and it came out fine... Link to comment Share on other sites More sharing options...
nodar1978 Posted March 14, 2009 Author Share Posted March 14, 2009 Just to see I ran Live Trace in Illustrator on it at default B&W settings and it came out fine... thank you very much, i'm not ilustrator user, i use max, but thank you enyway, I think it's good idea to start some practice in ilustrator as well. thank you Link to comment Share on other sites More sharing options...
