this kind of leather
chow choppe
This is something I came up with very quickly using Pix Plant 2 and a sample photo. I highly recommend a program such as Pix Plant for creating tileable bitmaps.
[ETA] I've added a cordovan diffuse map and a little sample render.
Edited by Fran
added images
thanks fran
i think i need to uvw unwrap the objects because the bump is not uniform as per the image.
also any idea about creating that kind of shiny look
Thanks
Yes, well you need to properly uv map your objects. You should also adjust the bump map's brightness and contrast to your liking. As for shinyness, the material setup will depend entirely on the render engine you are using.
