3d max shortcuts
bluediablito
quick question
is there any way to change 3d max shortcuts so that it would be the same as autocads shortcuts?
((( i have use auto cad since r14 and i am familiar with almost all keyboard shortcuts)))
how would i load or were would i find these files?
(((i know that for rhino you can do it)))
you can customise any shortcut key to be anything you like.
To modify or add new shortcuts, use the Keyboard panel of the Customize User Interface dialog. Keyboard shortcuts are separated by Groups or Categories of groups and they organize Actions.
I personally prefer to learn the keystrokes as per the default, so I can walk into anyone's 3ds max setup and start working.
thanks for the reply
i do understand how to change the shorcuts but i was hoping to find of a way to impor the same shortcut as autocad
the reason for this is that i learn autocad r12-2009 and i know mostly all of the autocad shorcuts.... now i use rhino grasshopper 3d max adobe cs3 autocad 2009 vray ....... and so on.... it would be nice to have a simple shortcut that will work on all (((well mostly 3d max, i aredy have rhino shorcut change to autocad )))
i have search the internet for a autocad shortcut for 3d max but no result.
if this is hopless then tell me
I'm not aware of an automatic shortcut importer for 3ds max.
They don't do the same thing, 1:1...
You could always make a custom set of shortcuts and offer it to your fellow AutoCAD/3ds Max users. :)
By using the default layout, if someone is having a problem ("Halp! My arrows have disappeared!") I can tell them "press X", etc etc
I've added a few things to my Right-Click (proxies being one of the most used ones) and there's always the Custom Floating Toolbar for custom scripts, too.
I know what you want, just offering other ideas for you.
Edited by SandmanNinja
My 1500th post! :)
