Animation to .3ds
Herthoren
Hi!
I'm a total newbie at 3d editing and hopefully won't have to get too deep into it, however I've been searching for a solution for this problem really intensively for a pretty long time, and I can't understand why I'm not finding the solution.
Using 3ds max 2009 (trial).
I have objects with skin animations, need to export them in .3ds format ANIMATED.
Found out .3ds doesn't support those, so seized baking plugins, finally got one working, it can bake to vertex animation or morph object seamlessly, the
animations are fine, the skin modifiers are gone (actually all modifiers for the vertex one) but THE .3ds FILE STILL WON'T STORE THE ANIMATION.
The model just stands there as it does on the frame the import was done from.
Tried Point Cache too but it simply didn't work. Watched the tutorial, did exactly as the Autodesk guy in the movie, but no matter what I try when I click on
the "disable modifiers below" button, the model won't continue to animate. Anyways, I doubt 3ds will support Point cache if it doesn't support morphing and
vertex animations.
Just to make sure it supports any kind of animation, I tried simple keyframe based ones and they worked.
However I don't know how to convert the skin animations into keyframe animations, but it must be possible.
So doesn't anyone knows a plugin that can convert my animations (skin or vertex or morph) into KEYFRAME ANIMATIONS? So the plugin should just store the
positions of all polygons, and sets them at every frame (there are no textures or particle stuff or anything)?
Or knows any other way to get my animations into a .3ds file?
Thank you very much
Thank you for replying.
Ideally, I want to export to Swift 3d.
(Actually, I need the final 2d animation in XAML, Swift 3D can render into that format)
I checked and noticed that .3ds does store simple timeline animation, so in theory, one could just make a 3ds export from every frame, import and merge them, and set the appropriate models to invisible at every frame they shouldn't be seen. Well it's impossible in practice with 23000+ frames and a lot of models, but I suppose in theory it could be done (I can export the different states of the models, the 3ds file will always contain the state they had at the frame I was on when I hit export).
Swift 3D supports: .3ds (along with animation - checked)
Not sure how well: .eps, .ai, .dxf, .dxb (autocad)
Edited by Herthoren
