Align Pivot (Hierarchy)
SandmanNinja
I've often wanted a "Align Pivot (Hierarchy)" with the same options as the Align tool (i.e. minimum, maximum, pivot and center).
I have had a need in the past to move the pivot so that it's EXACTLY on the edge or corner.
I've done work arounds where I Control+V and leave the copy exactly in the same x,y,x space as the original and then Align the original's pivot to the copy's x,y,z and then do the min/max/etc.
working with pivots is pretty simple, but i'm not sure I quite understand what you're trying to do..
you want an align tool that works on a whole hierarchy? or do you want to be able to shift the pivots of an object to the min/max/etc? If its the latter, take a look at the PivotPlacer script from the blurscripts pack.
