chadsmith Posted April 22, 2003 Share Posted April 22, 2003 Ultimately I am trying to make frosted glass effectively. I can add a little self illum. but the objects seen through the glass are still sharp and they should be blurry. Same for the reflections. Adding a bump map just disperses the reflection but not the objects seen through the glass. Even then the bump map does not disperse the reflection softly like frosted glass would. I wanted to know what you guys do for frosted glass so I can stop my abuse of ps. Link to comment Share on other sites More sharing options...
Craig Ramsay Posted April 23, 2003 Share Posted April 23, 2003 Try adding thin wall refraction in your materials refraction map slot. Change the refraction amount to about 45, go into the thin wall refraction seting and change the thickness offset to 0, change the blur to about 18ish and re-render.... instant blured glass Craig Link to comment Share on other sites More sharing options...
kid Posted April 23, 2003 Share Posted April 23, 2003 If you're just using scanline renderer you could use this script - http://www.jonseagull.com/downloads.shtml#arch_glass Link to comment Share on other sites More sharing options...
chadsmith Posted April 25, 2003 Author Share Posted April 25, 2003 THIN WALL REFRACTION IN NEW MATERIALS PUT INTO YOUR REFRACTION SLOT WORKED BEAUTIFULLY WITH A LITTLE BIT OF SELF ILLUM!!!! I SAY THIS IS THE WAY TO GO FOR FROSTED GLASS THANKS EVERYONE!!!!I APPRECIATE YOUR HELP!!! Link to comment Share on other sites More sharing options...
afecelis Posted June 1, 2006 Share Posted June 1, 2006 @Chadsmith: Could you share your material settings (opacity, self ilum, etc)? Link to comment Share on other sites More sharing options...
