help with the slice modifier.
craigball
Here is a script that iterates through all the objects in the max scene and if it finds an object that has a slice modifier it will delete it:
for o in objects do        --iterates through all the objects in scene
   if o.modifiers.count != 0 do        --if the object has modifiers
       for m = o.modifiers.count to 1 by -1 do        --iterates backwards through the stack to allow deletion
           if classof o.modifiers[m] == SliceModifier do deletemodifier o m        --if it finds a slice modifier it will delete it
Make sure you have a backup copy of the scene before you run the script. I've tested it on a few objects with multiple modifiers on it and it run perfectly.
You don't necessarily have to slice everything, you can simply use camera clipping. Set the distance of the clipping planes and everything outside of the clipping planes with be invisible.
Really thats cool dose it work with vray physicle cameas? do you know of any good tutorils for doing it?
thaks for that
