sir eel Posted February 19, 2004 Share Posted February 19, 2004 Hello all, I was perusing the tutorials on cg architect and found myself wondering how you guys get lighting results like these: http://www.cgarchitect.com/resources/tutorials/smoke3d/tut14_15.jpg http://www.cgarchitect.com/resources/tutorials/smoke3d/tut13_14.jpg I set up a small room with some windows. Just standard grey materials on everything and standard materials with transparency set really high for the windows. I put a sky light in the picture and a spot light with shaadow map shadows. I turn light tracer on and I get nothing just about a bacl pic. But can’t seem to get light through let alone to have it look like sunlight is pouring through the window. Any help would be much appreciated. Better yet if someone have a sample max file that I can download and study I would probly take up less of your time and learn alot faster. Thanks all. Link to comment Share on other sites More sharing options...
Babes Posted February 21, 2004 Share Posted February 21, 2004 Hi there,I am a new member with the CG Architect forums,even I get amazed with the stuff you all do,I am new user and don't know max much the lighting u all do is great,even i would like to learn some great things like that, your help will be highly appreciated,please try and help and please if you could tell me some links with tutotials with photometric lights,it will of great help. You guys are really great man. Link to comment Share on other sites More sharing options...
Jason Matthews Posted February 21, 2004 Share Posted February 21, 2004 Can you post your scene? You need to decide what kind of lighting ou want to do, radiosity or fakeiosity. This tutorial is good for ext. radiosity lighting. http://www.cgarchitect.com/upclose/article8_TB.asp Check out cgtalk.com, 3dtotal.com, help3d.com, 3dcafe.com, etc. Link to comment Share on other sites More sharing options...
vru Posted February 21, 2004 Share Posted February 21, 2004 The tutorial uses fakeosity. So use the standard lights as explained in the tutorial Lighting and shadow basics - part 3. Link to comment Share on other sites More sharing options...
Jason Matthews Posted February 21, 2004 Share Posted February 21, 2004 After thinking about it for a while, dont use skylight for an interior scene. I believe skylight is only for ext. scenes. Try using daylight located under systems in the create panel. Here you can adjust the sun and skylight while using light tracer. Follow the tutorial here to get a sense of light tracer, but dont use skylight. If you must use the skylight, it will take some tweeking. You must use other lights in the interior as well. I will try to find fakeosity tutorials for you but still look through the sites I recommended. I thought Ted Boardman had some tutorials up late last year. They were great. http://www.mrussoart.hpg.ig.com.br/more/tutorial/av/introav.htm [ February 21, 2004, 08:28 PM: Message edited by: Saturn ] Link to comment Share on other sites More sharing options...
Babes Posted February 22, 2004 Share Posted February 22, 2004 Hi there,thanks for posting the links,as I am a fresh guy i think it will take me some time to learn,thanks a million for the links I will go thru the tutorials and plz when ever you come around with good settings please do forward it to me,regarding interior and exterior lighting. Thanks a million. Link to comment Share on other sites More sharing options...
