Mr Max Posted March 19, 2009 Share Posted March 19, 2009 Hey everyone I wonder if anyone knows a way to reset the FFD 4x4x4 that tilts,rotates,twists etc with the object! i.e. If I apply FFD 4x4x4 to an object that has been rotated by 45 degrees, for example, and I apply the FFD modifier, it also rotates the control points by 45 degrees and it becomes so hard to play around with it! Thanks in advance;) Link to comment Share on other sites More sharing options...
SandmanNinja Posted March 19, 2009 Share Posted March 19, 2009 reset xform? Link to comment Share on other sites More sharing options...
amer abidi Posted March 19, 2009 Share Posted March 19, 2009 Expand the FFD subobject menu and pick "lattice" instead of "control points". You can then move, scale or rotate the lattice as you wish, then go back to control points to modify. Link to comment Share on other sites More sharing options...
Mr Max Posted March 19, 2009 Author Share Posted March 19, 2009 Both ways worked! Thanks a lot guys! you are the best Link to comment Share on other sites More sharing options...
