Vince Paske Posted March 19, 2009 Share Posted March 19, 2009 I'm doing some light studies using the Lighting Analysis Assistant and I think I'm missing something. When the Lighting Analysis Data window pops up, it displays a solid yellow color. The range of fc's in the scene are 35-78 and in the Analysis Value Color Coding dialogue box I set the min/max from 0-100. Shouldn't I see a color range in the greenish-blue to yellow-oranges? Link to comment Share on other sites More sharing options...
William Alexander Posted March 19, 2009 Share Posted March 19, 2009 Don't have an absolute answer, been a long time, however..... The tighter the min/max = greater color gradient for more evenly lit areas. maybe a min max of 30 - 80 would work better given knowledge of 35-78fc in your scene? Link to comment Share on other sites More sharing options...
Vince Paske Posted March 20, 2009 Author Share Posted March 20, 2009 I've played around with those values and yes, I can get the actual numerical values to read in the colors ranges specified on the rendering, but when the Lighting Analysis Data window pops up after the rendering is finished, it displays as solid yellow. So I'm either misinterpreting its purpose, or missing a buried setting completely. Thanks for the response. Link to comment Share on other sites More sharing options...
ramy Posted March 21, 2009 Share Posted March 21, 2009 The yellow window that you get at the end of a render is just a max frame buffer and doesn't mean anything useful. You can turn this off by going to your render settings, and clicking on the Render Elements tab. There is an option for the lighting analysis to uncheck the frame window. Link to comment Share on other sites More sharing options...
Vince Paske Posted March 23, 2009 Author Share Posted March 23, 2009 Thanks Ramy. It seems like it could be made useful and give meaningful information, its too bad it doesn't. Link to comment Share on other sites More sharing options...
pfbreton Posted March 25, 2009 Share Posted March 25, 2009 take a look at the daylight simulation white papers on autodesk .com you will get a lot of info on how to use this tool Link to comment Share on other sites More sharing options...
pfbreton Posted March 25, 2009 Share Posted March 25, 2009 Here: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=11360846 Link to comment Share on other sites More sharing options...
