Jonathan Posted March 21, 2009 Share Posted March 21, 2009 Is it possible to thicken autocad faces into a defined solid group of objects. I have an irregular shape made up of 3d faces yet I need to give it some solidity (wall thickness) Does anyone have any suggestions on how to work this? I have tried extruding faces yet this just causes gaps in the geometry. Thanks in advance. Link to comment Share on other sites More sharing options...
neil poppleton Posted March 21, 2009 Share Posted March 21, 2009 try extruding closed polylines. Link to comment Share on other sites More sharing options...
Jonathan Posted March 21, 2009 Author Share Posted March 21, 2009 Thanks I will give it a go. Link to comment Share on other sites More sharing options...
Stan Zaslavsky Posted March 22, 2009 Share Posted March 22, 2009 you can also add solid objects together once they are all solid (once you have extruded polylines into solids) Link to comment Share on other sites More sharing options...
alexg Posted March 22, 2009 Share Posted March 22, 2009 haven't really tried this, but maybe you can use 3dpoly (3dpolylines)? then you can extrude all the closed 3dpolylines Link to comment Share on other sites More sharing options...
3D_IC Posted March 25, 2009 Share Posted March 25, 2009 Extruding a 3dpoly line can create iregular results unless extruding along a path. depending on how eregular your wall is. I would try and break it down into sections model it as solids (extruded closed poly lines) then union them all together as one object. If the wall is too complex leave it as individual bits, not one large complex object. This will help Autocad and prevent crashing. Link to comment Share on other sites More sharing options...
Claudio Branch Posted March 25, 2009 Share Posted March 25, 2009 Import it into Max and use the Shell modifier. Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted March 25, 2009 Share Posted March 25, 2009 I believe so. It's in "that book I really like...." which I've put "somewhere, I'm sure of it." Got it. Two step process. CONVTOSURFACE, THICKEN. Link to comment Share on other sites More sharing options...
