danb4026 Posted March 21, 2009 Share Posted March 21, 2009 (edited) I have a large rectangle within which I want to place 9 evenly spaced smaller rectangles. I have tried using a plane the same dimensions of the larger rectangle and then using scatter to distribute the small rectangles evenly on faces, vertices, edges, etc. but nothing gets the simple result that I want. I know there are workarounds, but there has to be a simple command that accomplishes this quickly and I want to know what it is! Edited March 21, 2009 by danb4026 edit Link to comment Share on other sites More sharing options...
rmccoy Posted March 21, 2009 Share Posted March 21, 2009 I may be totally off here. but are you talking about trying to array an object? Link to comment Share on other sites More sharing options...
danb4026 Posted March 21, 2009 Author Share Posted March 21, 2009 All I want is to array or distribute the small rectangles inside of the larger rectangle completely evenly. Link to comment Share on other sites More sharing options...
WAcky Posted March 22, 2009 Share Posted March 22, 2009 (edited) Play with the array tool. Under the tools menu. or you could possibly make the plane have 9 even segments and continue to use the scatter tool with some sort or face centre distribution? Edited March 22, 2009 by WAcky Link to comment Share on other sites More sharing options...
SandmanNinja Posted March 22, 2009 Share Posted March 22, 2009 agree with the above array has 2D array options - "x" across and "y" down... or use scatter for each face I think array would be the easiest Link to comment Share on other sites More sharing options...
Dave Buchhofer Posted March 22, 2009 Share Posted March 22, 2009 http://andklv2.narod.ru/maxscripts/ak-maxscripts.html look for Grid Scatter partway down. Link to comment Share on other sites More sharing options...
rmccoy Posted March 23, 2009 Share Posted March 23, 2009 the above plugin is also on script spot. it looks pretty useful. http://www.scriptspot.com/3ds-max/gridscatter Link to comment Share on other sites More sharing options...
LuckyST Posted March 23, 2009 Share Posted March 23, 2009 create 9 rectangles (3x3).. select them, and "align" them to be in the center of the larger box. another option is constructing it in autocad, if you want it to be "perfect". Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted March 26, 2009 Share Posted March 26, 2009 Create plane with correct number of divisions. Conver to Poly. Select faces. Inset per polygon. New polys should be only ones selected. Detach to new object or shift clone or whatever. Possible issue is that the outside gap is half the distance of the between gaps. Link to comment Share on other sites More sharing options...
