texturing a loft object
LuckyST
I have a problem....
I have lofted a section along path, and applied the mapping.
but my results are not what I want them to be.
I'm trying to achieve the map to be constantly perpendicular to the loft path, but when I use to little "path steps" (0) to get a simple mesh...
the whole thing gets distorted. (pic 1)
but if I use to many "path steps" - 20 ... I get the mesh pretty screwed up... and I'll have to spend who knows how much time editing it out later on.
is there a simpler way to get what I'm looking for?
thanks.
thanks for the tip...(vertices to corner) but still nothing :(
I've tried adding width to the path, and seeing how it gets mapped, and I concluded that it's mapping paramaters are translated to the loft later on, and are causing the whole texture warping.
If I increase the number of vertices along the spline, I get the textured result I was looking for... but then again, I get the polygon overlapping, which would again mean I'd have to go into edit poly, and sort it all out which would again take me days to sort out... and I probably would get a bad result later on when texturing&rendering.
here's what I get when I divide (refine) the path...
the textures look better (but not yet perfect)... and I get a bunch of redundant polys... and a bunch of overlapping polys :(
Edited by LuckyST
