TomD_Arch Posted March 23, 2009 Share Posted March 23, 2009 I am using a displacement map for this stone wall and now there is the issue of the wall pulling apart. Does anyone know how to fix this? I feel like this is going to be a duh moment so place forgive me if this is a "You should know this" thing. Link to comment Share on other sites More sharing options...
Stephen Thomas Posted March 23, 2009 Share Posted March 23, 2009 Check out this thread: http://www.cgarchitect.com/vb/35144-there-displacement-mapping-edge-work-around.html Should give you the answers you need. Link to comment Share on other sites More sharing options...
acjwalker Posted March 23, 2009 Share Posted March 23, 2009 are you using vray? if so you need to put a vray displacement modifier on the object. And tick the box "use object material" and "keep continuity" Then in your material slot put your displacement map in the displacement slot. This should sort your problem. Link to comment Share on other sites More sharing options...
Stephen Thomas Posted March 23, 2009 Share Posted March 23, 2009 are you using vray? if so you need to put a vray displacement modifier on the object. And tick the box "use object material" and "keep continuity" Then in your material slot put your displacement map in the displacement slot. This should sort your problem. If you're using a vray displacement modifier then why would you want to put a map in the displacement slot of the material as well? Link to comment Share on other sites More sharing options...
TomD_Arch Posted March 23, 2009 Author Share Posted March 23, 2009 I am using mental ray and dont have v-ray, so the link above doesnt really help. I am using a "standard" material with a map in diffuse and displacement slots. Still have no idea how to fix this??? Link to comment Share on other sites More sharing options...
Ky Lane Posted March 24, 2009 Share Posted March 24, 2009 (edited) Are you using the 'sepcial effects" displacement, or the "mental ray connection displacement"? Use the latter (its further down the material rollout). Unlock it, add a "height map displacement", and then add your bitmap to that - make sure that you use inverse displacement though, as in, make the max 0, and the minimum the height you want in a neg value. You can up the details in the map by 1> lowering the blur on the bitmap map and 2> changing the values in the render rollout for displacement (under 'Render" by memory, or one of the other tabs). Make the edge length smaller and itll render more precisely (And take longer). I wouldnt go below 1.0. Edited March 24, 2009 by Ky Lane Link to comment Share on other sites More sharing options...
