how to get rid of noise on glossy materials
nelpiper
Hi guys. I know this topic has been widely discussed but does anyone have a good and certain way to get rid of the noise like the ones on the render? It seems that whenever I make a material glossy reflective, this kind of noise pops up. Thanks.
Your image sampling settings are probably stopping vray from resolving the noise. Go with Adaptive DMC, min=3, max=6, disable the 'use DMC' box and set color threshold to 0.001. That should eliminate your noise issues.
If you want a good tutorial on image sampler settings here's a couple of places to start:
http://www.cgarchitect.com/upclose/VI/Week17/image_sampling.pdf
http://gnomonology.com/tutorial/62
Hi guys. I used a falloff in the reflection glossiness slot and worked quite good. Still got some noise but is perfectly acceptable. The interpolation doesn't work for me as I had a bad experience in the past because this is an animation. Still thanks for the tip. Thanks all guys.
