Can't remember comand...
carlangas
In the loft tab, use the percentage spinner and the option to choose different profiles in different postions. Basically first make a loft, then go into the modifier tab, and add more profiles from there, chosing the appropriate distance along the path. Hope that helps.
Thanks for your input Jakub, This is what I came up with, do you know why its blending like that to the other profile? the two profiles are the same exept for the backrest which is suppoesed to be longer. :confused:
Looks like they have a different first vertex. You can go back to the profile shapes, vertex mode. Select a vertex and hit the "make first" button. Make sure each profile has the "same" vertex as its "first" and you should be grand.
thats a great tip, didnt know that so I had to redraw the profiles.
