mental ray proxy problem
dpcaltdcah
I'm trying to turn an xfrog tree into a mental ray proxy. We have max design 2009 and I have my tree as a single mesh object. I've tried both the way suggested in the help files AND the way suggested on mentalraytips.com with his plugin. both work just fine on other objects but not on my tree. It just renders blank even though the little proxy preview window shows a preview of the tree. The "point cloud" preview doesn't show the shape of the tree either...
thoughts? suggestions? I'm normally a vray user, is there something obvious I'm just not doing?
All the trees and bushes in this scene are MR Proxies from Xfrog models. You should be using Master Zap's plugin that creates a proxie out of multi-objects and you will need to re-apply the material to the proxies. In addtion the point cloud display is all that I believe is available and this makes it hard to locate stuff accturately. Hope this helps and sorry if I am repeating what you have already done, but it can be done ;)
http://www.3dallusions.com/forums/attachments/mr-max-wips/9172d1236469027-thorncrown-chapel-extclrtest50sml.jpg
Edited by Russell L. Thomas
