djoshi Posted March 27, 2009 Share Posted March 27, 2009 Hi, check this link. I want to know that how to do such animation? Have they manually animated each piece OR there is particular script available or plugins OR any trick.??? Has anyone done like this before..pls. share..! Thanx in advance.. Link to comment Share on other sites More sharing options...
TomA Posted March 27, 2009 Share Posted March 27, 2009 not sure but this might help: http://www.cgarchitect.com/vb/35127-unfolding-architecture.html Link to comment Share on other sites More sharing options...
Neil_cg Posted March 31, 2009 Share Posted March 31, 2009 It's done with particle flow. you slice your geometry up and make it into seperate objects, use a birth script in particle flow to create a particle at the location of each piece of geometry/bind it and then you can animate the particles as a whole and it will drive the geometry. Some hand animation wouldve been used for the more precise/one off movements, but it'd be impossible without pflow. Link to comment Share on other sites More sharing options...
smvwhite Posted June 1, 2009 Share Posted June 1, 2009 I think I have found a tutorial or two on the particle to geometry bit. Does anyone know of any slicing maxscripts (that would cap ends)? Found some on scriptspot but they don't seem to be able to dice objects up too well. Link to comment Share on other sites More sharing options...
paragsm Posted June 1, 2009 Share Posted June 1, 2009 hey Joshi. Nice question even there is one othe advert in which the bridge is created in the same way. Even I wonder How to do it. Link to comment Share on other sites More sharing options...
paragsm Posted June 1, 2009 Share Posted June 1, 2009 Try this this one is relatively easy but amazing. Link to comment Share on other sites More sharing options...
smvwhite Posted June 1, 2009 Share Posted June 1, 2009 As all the animation appears similar - perhaps 3D Architecture Animation Creator Professional was used? www 3dbrother dot com Link to comment Share on other sites More sharing options...
paragsm Posted June 1, 2009 Share Posted June 1, 2009 gr8 link thnks. Link to comment Share on other sites More sharing options...
