M.H.B Posted November 29, 2003 Share Posted November 29, 2003 hey every one!!! i am having some problems when i am trying to weld some vertices...actually the problem is just one...i was doing fine, but out of nowhere i started to recieve this msg : No vertices within weld threshold : i already tried to change those parameters in weld panel but the msg keeps poping up! thanks! Link to comment Share on other sites More sharing options...
xgarcia Posted November 29, 2003 Share Posted November 29, 2003 It means the vertices are already welded and there are no more within the threshold to weld. Usually this happens if you already welded them or if you've selected only one vertex. Link to comment Share on other sites More sharing options...
M.H.B Posted November 30, 2003 Author Share Posted November 30, 2003 the thing is that i can see two different vertexs i know that they are not welded, and i know that i selected both of them....thanks anyway, but i had to move on....i guess this won´t make a difference in the final image.. Link to comment Share on other sites More sharing options...
xgarcia Posted November 30, 2003 Share Posted November 30, 2003 Ok - turn down the threshold. To something like 0.01....see if that helps. You're right - won't make too much of a difference, especially if you use a smooth modifier. Link to comment Share on other sites More sharing options...
nisus Posted November 30, 2003 Share Posted November 30, 2003 Hi all, Hi MHB, I'm not sure, but I assume this is a 'max'-question. If so, pls inform me so I can move this thread to it's appropriate section. rgds nisus Link to comment Share on other sites More sharing options...
M.H.B Posted November 30, 2003 Author Share Posted November 30, 2003 yeah, this is a max question....sorry about that nisus...i am kind new here... Link to comment Share on other sites More sharing options...
xgarcia Posted November 30, 2003 Share Posted November 30, 2003 opps...I forgot to ask if this was a MAX question. I just assumed b/c it dealt with welding vertices, but I guess other programs have this as well. Link to comment Share on other sites More sharing options...
Jonny English Posted December 1, 2003 Share Posted December 1, 2003 I get this sometimes. I find if it doesn't weld after I've clicked a ew times, then I use 'fuse' and this works, but might throw the vertices out of their plane. I think it occurs when vertices end up somewhere in 3D that you did not mean them to, if you have 3D snap on by mistake instread of 2.5D Snap. Link to comment Share on other sites More sharing options...
