Jonathan Posted March 29, 2009 Share Posted March 29, 2009 Hi, Is it possible to create a 3d section (architectural visualisation) in 3ds max. I have read that all objects must be attached yet I dont think this is appropriate particularaly for a large project. If Microstation can do it surely it is possible in Max? Thanks Johnny Link to comment Share on other sites More sharing options...
neil poppleton Posted March 29, 2009 Share Posted March 29, 2009 Try slice modifier Link to comment Share on other sites More sharing options...
ankit4d Posted March 30, 2009 Share Posted March 30, 2009 convert whole scene in edit poly, attach all the object and make it a single mesh, and then use Quick slice. Link to comment Share on other sites More sharing options...
Sketchrender Posted March 30, 2009 Share Posted March 30, 2009 This is one of my biggest problems with max. As most of you will know , the architects never ask for a straight section most of the time stepped, or some other dodgy angle. So slicing a model and then after you butchered you model a s saved version obiously they want to move the section. Revit, sketchup all have great section tools. Any chance this can be intigrated , it would stop me moving to revit. Phil Link to comment Share on other sites More sharing options...
SandmanNinja Posted March 30, 2009 Share Posted March 30, 2009 You could probably make a simple macro script open listener clear the window hit HOLD attach them all together into a single object then bring the slice tool out and center it on your model. When you move it where you want, slice it When you're through, just do a FETCH Link to comment Share on other sites More sharing options...
jsf Posted March 30, 2009 Share Posted March 30, 2009 Cameras in Max have clipping plane controls you can set manually. Link to comment Share on other sites More sharing options...
postite Posted April 1, 2009 Share Posted April 1, 2009 Yes, but with other apps, it's possible to export the spline created by the section. Very helpful for presentation in AutoCAD or ArchiCAD. I've recently discovered another section tool in Max. It creates a spline. It can be useful in some cases. ==> Create/Shape/Section. Steph Link to comment Share on other sites More sharing options...
3dp Posted April 1, 2009 Share Posted April 1, 2009 if you have a bit of time and spare $$ the head over to cebas plugins and have a look at their scapelmax toolset basically it a interactive boolean type tool very stable and you'll get the stepped sections with multiple instances of scalpel applied to mesh used lots in the past with no issues Link to comment Share on other sites More sharing options...
