Michael J. Brown Posted March 30, 2009 Share Posted March 30, 2009 I know there must be a simple solution to prevent the severe light bleeding I'm getting here. I'm guessing one of my settings is just not high enough. Please advise. Link to comment Share on other sites More sharing options...
Dave Buchhofer Posted March 30, 2009 Share Posted March 30, 2009 try check sample visibility in irradiance map, also try secondary ray bias to a very small number (.001) in globals Link to comment Share on other sites More sharing options...
Michael J. Brown Posted March 30, 2009 Author Share Posted March 30, 2009 Will I need to reset my Irradiance and Light Cache maps when I re-render? Link to comment Share on other sites More sharing options...
Brian Smith Posted March 30, 2009 Share Posted March 30, 2009 Dude, You have some bizarre and unusual settings going on. I'd start over with the default settings and change only things when you know for certain what they do. I don't think that's light leak. I think it's your inaccurate light cache. You have your sample size set way high at 0.1. That should be left at default (0.01) to start with. Besides that, you've also got interpolation turned off on LC, PreFilter turned on, and Number of passes possibly set to low for your machine. The biggest culprit to true light leaking is when you don't have 'Check Sample Visibility' turned on in the irradiance map....but that aint the problem here cuz this aint light leaking. Link to comment Share on other sites More sharing options...
Michael J. Brown Posted March 30, 2009 Author Share Posted March 30, 2009 Thanks Brian. This did the trick. Link to comment Share on other sites More sharing options...
gato_maxx Posted March 30, 2009 Share Posted March 30, 2009 Heres a "cheap" trick: Go to the saturation setting and change its value to 0.5. Link to comment Share on other sites More sharing options...
manta Posted March 30, 2009 Share Posted March 30, 2009 Heres a "cheap" trick: Go to the saturation setting and change its value to 0.5. that will work with color bleeding, not light leaking... Link to comment Share on other sites More sharing options...
